  • Upcoming Events
  • Member Statistics
    8,621
    Total Members
    1,713
    Most Online
    Cruisy72
    Newest Member
    Cruisy72
  • Who's Online   0 Members, 1 Anonymous, 76 Guests (See full list)
    • What year and spec? FYI most places will still list car as legacy not levorg though.     here’s the 2020-current model  https://www.subaru.co.nz/sites/default/files/2023-09/Subaru_Warranty_Service_Book_2020_SNZWRTY17.pdf   try https://www.subaru.com/owners/vehicle-resources.html the owners manual for some models are 500 pages and have the service guides.   Or select your year and spec and click the button.  https://www.subaru.ca/webpage.aspx?webpageid=18541
    • Hey Guys,    Recently bought a Levorg and am struggling to find a servicing schedule maintenance manual or list of what’s required/recommended at x kms.  Does anybody have a copy of this?
    • Wired cruise control into my 07 BP, then carried on drive line swapping my 02 BH, fit new diff axle seals and o rings, re assembled rh front hub, stripped the threads on my brembo caliper 🙃 and re fit the starter.
    • Ran aux cable for stereo to centre console in preparation for airplay wifi unit. It’s an old single din unit and aux is via an adaptor via CD changer input.   Finally fixed the door lock in the inner handle. When the door was replaced from the attempt to screwdriver the lock they used the lock and cable from the new door. Which has a smaller ball on the lock the the main handle. cheap fix since only used heat shrink to cover the small ball with 3 layers and now it clips into place and works fine.
    • Looking to tidy up the clutch master to bring it up from under the intercooler and while at it maybe the brake master.   Anyone done remote mounting before?   https://au.gktech.com/products/remote-mount-reservoir-kit
  • Latest Products
  • Popular Contributors
    • Total Topics
    • Total Posts
      574k
