Happy 2025! We're Still here ×
  • Upcoming Events
  • Member Statistics
    8,621
    Total Members
    1,713
    Most Online
    BruserNZ
    Newest Member
    BruserNZ
  • Who's Online   1 Member, 0 Anonymous, 106 Guests (See full list)
    • Nothing Subaru as of the past 4 years? Other than Put a Battery in it and move it to mow the lawns     still needs a head gasket : still have a Spare V4 Motor on a Pallet in my Shop   Instead : I put a Battery into the Red car and Drove it to Local Car Club Meeting last night 😎    Auto-X's coming up so now I have motivation to fix that!
    • Installed one speaker in passengers door, ran out of time with other little bits I found today.   Found sound deadening was pushing old speaker into grill. Was the 2mm tar and foil stuff. Removing it isn’t hard but the foil is razor sharp as I found out.   Ground inner grill to make more clearance. Added some foam to door skin where no factory wool was covering.   Found issue with driver door lock. passengers one has a ball and little pin. Drivers one doesn’t have the pin. Must have broken off when they tried to break the lock.   found air vent to passengers front foot well was unclipped and loose. How it came loose I don’t know but it was a pain to get it clipped back in.
    • does any body have the info for the pills on a ej206 with VDC ?
    • Replacement fender badges arrived. This time they are the correct ones, so stuck those on.   Ordered 63269FJ120 replacement hatch gas struts as they started to not open fully in the last few weeks.  Generic replacement antenna as the original one is a bit bent. sideskirt large push clips as found that a couple are missing. assorted panel clips as missing some from wheel liners.
    • hi ya & welcome to the forums, I noticed you double posted, not really necessary, so I've move the other to the Recycling bin ❤️   Hopefully you find a solution
  • Latest Products
  • Popular Contributors
    • Total Topics
    • Total Posts
      574.1k
