  • Upcoming Events
  • Member Statistics
    8,553
    Total Members
    1,713
    Most Online
    Rayden
    Newest Member
    Rayden
  • Who's Online   0 Members, 0 Anonymous, 56 Guests (See full list)
    • This was damn near 12 years ago, I don't remember much 🤣   The thing I replaced was somewhere behind the dash on the passenger side. I think I had to remove the passenger side air vent to get the bolts.   Can't remember exactly what I soldered. I think it had something to do with making the car lock/unlock with the alarm remote. It was two wires coming from somewhere.
    • The multi screen 2015+ one with airbag light, aircon and information display. Not the later 2017+model ones that are one big screen with aircon and info in one.
    • Try Aliexpress a new Clip for the programmer or breakout board. then any electronic repair shop could place it on transfer it over and you can reprogram it. If you bring a laptop to reprogram it they may just charge you the hour. or order and program a new rom and then have the shop swap it.   or they make mileage correction tools for $150.   does freeSSM do mileage?     Or you could just tin some wire and attach it to the chip or points like the picture while it’s still on the board. Since you are only doing on leg at a time it won’t move. And looks like 4 or the 6 point are via holes. just heat the solder on the wire and then touch it to the board. No need to put soldering iron to the actual component until you need to remove them.      does the counter go around at 999999 or get corrupted?
    • Hey guys, I've recently done a '15 WRX odometer/cluster swap into a Levorg and need to sort the km's out. I have had a bit of a look at the 93C76 chip on the back but realized my clip tool won't quite get it and my clunky soldering iron/shakey hands have no hope of transferring the chip onto a breakout board or similar.   I am thinking that to send the cluster off to someone who has a hot air soldering station and an idea of how to read/write binary files is probably going to cost an arm and a leg. Has anyone had this done? Idea of cost? And where?     I was wondering if I could instead, simply send a PWM signal into the cluster for a few days (300kph, more?) in order to let the km's slowly accumulate upwards. (I could add 7,200 km per day, so would have the change completed within the week)   Has anyone done this before? Bonus points awarded for anyone who has a cluster pinout and knows the voltage for the speed signal.   Cheers
    • https://www.trademe.co.nz/a/motors/cars/subaru/impreza/listing/4927230206   Big power 6-speed tranplant Tuned Link etc 410 whp on Ecopia tyres ???   🤣
  • Latest Products
  • Popular Contributors
    • Total Topics
    • Total Posts
      573.8k
