  • Upcoming Events
    No upcoming events found
  1. General
    1. General Vehicle Discussion
      General discussion board for anything car related
      102.9k
      posts
    2. Stolen Vehicle Register
      If your missing something or have information about things lost
      4.9k
      posts
  2. Knowledge Base
    1. General FAQ (Read Only)
      Non-model specific frequently asked questions relating to Subarus. (Read Only)
      If you have something to add, contact one of the Mod team (Full List HERE)
      43
      posts
    2. 80.1k
      posts
    3. 87.7k
      posts
    4. Legal
      All things regulatory, WOFs, Standards etc
      2.9k
      posts
    5. Motorsports
      Track day and MSNZ specific discussion
      1.8k
      posts
    6. "Other" Tech Questions
      discuss anything non Subaru related, your tools or how to fix a Lawnmower in here
      648
      posts
    7. Product and service reviews
      Share your first hand experiences good or bad.
      336
      posts
  3. Regions/Events
    1. ClubSUB Events
      Only things we're involved with such as Flat-Nats
      9k
      posts
    2. Auckland/Northland
      General discussion board for all our Auckland/Northland members
      Moderator : ADIKT:
      17.9k
      posts
    3. Waikato / Bay of Plenty / Taupo
      General discussion board for all our members in the Waikato, Bay of Plenty, King Country, Taupo.
      Moderator : nztintin
      2.1k
      posts
    4. Taranaki / Whanganui
      General discussion board for the Taranaki and Whanganui areas
      25
      posts
    5. Manawatu / Wairarapa / Hawkes Bay
      This team represents the East Coast, Hawke's Bay, Manawatu, Poverty Bay, Wairarapa-Bush areas
      5.4k
      posts
    6. Wellington / Kapiti
      General discussion board for all of our Wellington and Kapiti based members.
      Moderators : Chulozumo & Sc00byd00
      10.5k
      posts
    7. Nelson Bays/Marlborough
      Topics relating to Nelson Bays/Marlborough
      Moderator: VACANT : apply within
      76
      posts
    8. Canterbury
      From Timaru to Kaikoura, the Port Hills to Mt Cook, Its all Red and Black here!
      11.7k
      posts
    9. Otago / Southland
      General discussion for all our Otago / Southland based members.
      Moderator : Tydon
      7k
      posts
    10. Outside NZ
      Post & share your international events & see who's active in your Neck of the woods
      15
      posts
  4. Classifieds
    1. Car Exchange
      Buy / Sell / Trade vehicles
      post
    2. Parts Exchange
      Buy / Sell / Trade car parts
      post
  5. ClubSUB Shop
    1. ClubSUB Shop
      The place to go for Subscription purchases/renewals, stickers, banners, t-shirts and anything else we can get our logo on.
      posts
  • Member Statistics
    8,623
    Total Members
    1,713
    Most Online
    LOL1NE
    Newest Member
    LOL1NE
  • Who's Online   0 Members, 0 Anonymous, 91 Guests (See full list)
    • Refitted windows switches and they all work again. Very surprising as the passengers ones was so bad it felt like it was physically broken before taken apart. And once part the slider got stuck and felt like it had grit or bent contacts inside.   So I looked up some replacements overnight.   standard auto up/down drivers RHD https://www.aliexpress.com/item/1005005240228470.html but found on the later Nissans they had higher model ones with auto for 2 or all 4 windows. https://www.aliexpress.com/item/1005006046168940.html https://www.aliexpress.com/item/1005004633745295.html   this would be up to the body control module BCM but since there is no additional wiring for auto it could support the additional auto functions already.
    • Removed drivers door window switches as passengers switch is busted.   Pulled the top off and actual switch under rocker gets rough near the ends. Poured ethanol into the gaps and worked switch. Seems to have washed out whatever crud was inside.   It’s a Nissan part and reasonably common. Just harder to find in RHD but will order a replacement if it doesn’t work now it’s clean.
    • Ordered 6mm thick SiO2 Silica oxide aerogel sheet to wrap downpipe. It’s classed as incombustible, good for 800c and at 10mm thickness can reduce 650c on one side down to 50c on the other. its hydrophobic so won’t absorb liquid and chemical resistant as well.   Then going to them wrap the aerogel in common adhesive glass-fibre cloth with alloy so it has abrasion resistance.   The exhaust is already ceramic coated but it’s still getting too hot near the steering rack and both the brake and clutch master cylinders.
    • Holden astra and most ev cars have similar pump and tank in one units as well.    edit.. plus  Audi Seat Skoda Volkswagen POLO FOX LUPO  like 6Q0423155AE 6Q0423155AB 6Q0423156E
    • That mopar way seems like a heap more effort. The Volvo should be just a matter of new supply and return lines then power. Some people even run it with no signal stuff working so it goes into a sort of limp mode and just runs a fixed percentage assist, something like 60-70%   It would be interesting to see real world amp draws on the Volvo, I’d assume it’s usually quite low and only sees anything particularly high during full lock at crawling speeds where there’s probably enough grunt in the battery to negate the shortcoming for short bursts.
  • Latest Products
  • Popular Contributors
    • Total Topics
    • Total Posts
      574k
