ABS light 1990 VZ
Guest the_return_of_the_jedi
hi.. randomly the antilock braking light shows up in my VZ.. not all the time tho..
is this due to the pads being sort of low.? also could it be time to change the brake fluid etc...
or will cleaning the sensors at the brakes fix this?
it has the abs unit in the front right of the engine bay and is 4 wheel abs
cheers
No, no and no.
Next time the light comes on, pull over and leave the ignition on.
Roll the drivers seat all the way forwards.
Under the carpet next to the sill is the ABS ECU. Lift the carpet flap so you can see the flashing LED.
Count the flashes.
I'll see if I can find the list of fault codes.
Mine was the same, but ever since I lowered it, the light hasn't come on again. I can only guess there's a damaged wheel speed sensor and lowering it has closed up the broken wire or something. ABS works fine anyway.
Bust out the multimeter and check the resistance of both front sensors. They should be around 1000 - 1200 Ohms. Unplug it at the first connector from the sensor and measure there. I think you'll find the RF sensor will be open circuit.
