IMPREZA HELP! try here first
kamineko
As the Tech forum is rebuilt, links to good helpful threads will be posted here.
If you can't find it here, try the search.
if someone has just done a writeup (CHEERS!) PM me and i will add to this list a-sap :)
CEL related:
Check Engine Light CEL How To
CEL code 31, EJ20G TPS Throttle Position Sensor (EJ20G only)
CEL code 42, Idle switch (EJ20G only)
Chassis related:
WRX Classic Model Codes
Removal of spoiler
Earthing Mod
Driveline related:
DCCD Info
CV joint replacement
Removing gearbox from engine
Sloppy / Floppy shifters - DIY Guide inc'd
ECU related:
JDM WRX ECUS
ECU Pinouts BC5 BG5a WRX (4 plug) pinouts
Engine related:
Keltic's DIY Air Filter, Oil and Oil Filter Change
Tips when replacing coils
Changing a fuel pump
WRX V2 sti injectors. V2 Grey vs. V3 Yellow
Intakes
Sti vs non Sti blocks
Alternator and Power Steering Belt
TD05 vs. VF23
How to: Rocker Cover Gasket Replacement (Fixes leaks onto exhaust manifold)
Wheels / Tyre related:
V7 STi +38 offset?
yeah these links worked on the previous forum. maybe try searching the thread title to find them here
Edited by kamineko
  • 1 year later...
  • Joker unpinned this topic
