Wrx sti type r
chrisp
Thanks mcdoof. However I've read those. My question is whether it's different from your standard sti. Example. Mine has grey injectors not yellow. It has standard color heads not red. However it is running vf 24 and orange sticker airflow. It appears to be running a combination of wrx and wrx sti parts. I've just never seen that before.
hi evowrx. now that you mention it, I will double check that. Any ideas about what sort of ecu. Im not clued up with that side of things. and as you can see manifold is not red and has no evidence of being painted red.
1S ECU = Version 3/4 WRX (non-STi) which goes with the Orange AFM and Yellow injectors.
The only coupe model I'm aware of that has a standard WRX set up is the Type R V-Limited.. but that's factory blue in colour.
Grey injectors would be common on V1/2 WRX's and STi's or Version 3/4 WRX Wagons, but the V3/4 WRX Wagon runs a 2s ECU with a Purple AFM and TD04 turbo.
No its not possible yellow is yellow. 6s ecu = V3 1s ecu = V4
Should have subaru 2 pot rear brakes and r180 rear end with plated diff and dccd gearbox ifs its limited it will have front helical lsd diff
Edited by hijacka
