Weird noise when turning
Rzalza
Hi all, I have a 2003 Subaru legacy gtb wagon and have just had fixed. A new oxygen sensor, leaking thermostat gasket and cv boot. Now before I took it to winger Subaru to get all this fixed I told them I had started hearing a clicky noise when I turn the steering wheel and I thought it might be the cv joints. They had a look at the cv joints when replacing the boot and said the joints look fine but I still get that clicking noise after I've driven the car for a bit and it sounds terrible, like ****ed cv joints. What else could this be if they said the joints looked fine? The noise only happens after I've driven the car around for a while.
If they only click when turning and there is no noise while driving straight it's the cv joint (one or both). Being that a boot was ripped it means that grease has escaped and dirt has entered, which will almost certainly lead to damage.
usually wheel bearings will make noise at all times and not just when turning
CV's can wear out over time without the boot failing or splitting. Or your CV's might already be on their second set of rubber boots too.
They've inspected the inside joint when replacing the boot, but could be an outside one that's clicking. Or as above, it's been split for a while now and was completely dry so has been damaged. It's been repacked with grease but still not enough, it needs replacing.
Edited by Rosssub
