Pic wanted of seatbelt mounting location
Scoobydoo
Can someone please post up a close up pic of how the seatbelt stalk is mounted to the rail - is it mounted to the rail / runner, or to the seat itself?
This is to figure out how easy / legal it will be to install a race seat onto factory rails.
IE: can the seat itself be removed from the rails, with the seatbelt staying on the rails?
Preferably on a seat from a V7 or higher WRX / STi.
I'd also like close ups of the underside of each rail as well, as well as dimensions of the bolt holes that hold the seat to the rails.
Cheers :)
Edited by Scoobydoo
  • 3 weeks later...
Not bothering with it for now, so don't worry.
I was planning on getting a Racetech seat, but it seems that certing issues are tough to get around.
If you can use the seat using factory rails without modification, and the seat belt anchorage is in the same position as OEM.. then no cert is required.
I'll sort it out if / when I have more time / can be bothered.
