Light wheel options
Hey guys, what light weight wheels are you guys running in 18x10ish? 5x100.
I'm in the market and looking for option's. Currently running 17x9s with 35p.
Or can anyone recommend someone to deal with for them? Something I've never really dealt with.
After light as possible.
Thanks
 -BLKREX- said:
18x8 is widest I've found in 5x100.
Anyone ever run with success the 20mm converter spacer? 5x100 to 5x114.3?
Yea youre right special order I think. The later hubs are stronger iirc tony/dtech was saying something about it a while ago.
Yeah they are stronger. I kinda went about it the stupid way. Whenless I brought the 6speed sequential I had billet stubs made so I didn't have to change hubs. But now I want to go wider tyres and back to the hub problem. Should have dealt with it at the start. But again, then I'm messing with struts and brakes etc etc. Headache much
Brakes arent an issue with swapping to 5x114 hubs (v9+ STI), brake discs will need to be redrilled or replaced but the caliper mounts are the same so your current stuff should swap straight across.
Suspension strut clevis is wider but it can easily be milled down and the top hole welded up and a new hole drilled. Not complicated...
Edited by Optical
Thankyou. Doesn't sound as bad as I thought actually.
Are the 5x114 hubs pretty rare? Something I haven't ever kept an eye out for
 Optical said:
I had to wreck a whole version 9 to get my set :/
that was about 6 years ago though, I'm sure they will be easier to find now.
Hopefully it doesn't come to that. I actually got quiet a few parts out of Oz for my sequential from a late model sti. Sure I'll find something
Thanks
 EJ20T said:
Are GRB hubs compatible for the swap or are they different to v9 v10?
They are a little different (ABS sensor location, and I think height of steering arm is lower?), but still usable for this application as BLKREX's car has adjustable bump steer bits so would just need adjusting to suit the new set-up...
Wouldn't Enkei do custom order, work wheels do? So you can specify exactly what you want. it's what im doing with my work wheels but im not bothered about lightness.
Yeah I'm sure they would. I'm just trying to decide what to do whether custom wheels or hub change. The entire car has been built around weight so I'm fairly keen to keep it at its 1034kg ish if I can
Light wheels are better all round.
Did you order wheels recently I have been waiting like 5 months for mine to arrive
