quality of Sti branded Genome Strut btace
Strongs are somewhat funny sometimes. Some things are cheap, some are ridiculously expensive.
From my own experiments with the braces (believe me, I tried all of them on my BLE :D - out of curiosity and just because I could) I'd go with Cusco or similarly build/designed one.
Genome for $45 should still deliver though ;)
 patrickc22 said:
So it will have no effect
Do not expect much from it, on its own at least. I do notice the difference, rear strut brace was a much more noticeable upgrade on my old GT-B though.
A lot of people (Americans in particular, seems like all their care about is stance and more horseys) will argue that front braces are just a fetish/cosmetic mod. Most of them never installed one and just heard something somewhere.
PS: IMHO
It will increase the bling factor of your car and being genome its worth millions to most people on here. As far as handling goes its prob not going to do a lot considering its not adjustable.
That said i had an sti one fitted to my car and i dont see sense on removing it. For 45 its worth grabbing imo. Rear strut brace in a wagon makes a lot of sense.
I would like someone to tell me what the strut tower deflection is under cornering at a given lateral force, and thus what forces a strut brace is required to withstand to become useful (given that people spend big money on removing millimetres of deflection in bushings which is undoubtedly effective).
A chassis flexes a lot more than you might expect - try opening all the doors on a car then jacking it up as close to the corners as you can, then close the doors and check out the panel gap compared to normal.
If you think about the direction of the forces when you hit a bump the strut towers will try to get closer together, even if it's only by a tiny amount. A decent strut brace will resist this force to a degree - how much that degree is, I don't know - I have a feeling that it's tiny, personally.
Bit of a carry over from the old escorts that tried to clap hands with the strut tops..they are needed on the old school stuff when used in anger..Not so much with modern cars..
no triangulation most likely means not much.
I remember an old member on here saying that the BH legacy wagons and later don't need a rear bar as much as the older ones as they have a different rear suspension setup meaning there is less/little/no stress/contortion on the chassis... in the rear that is, front still a good idea...
don't know how much truth there is in that statement, just putting it out there...
Not much, I ended up putting one and never regretted. First you'd simply notice that there's much less noises coming from the back, then you go for a drive a notice how more responsive and in one piece the rear is.
(or I might just have a super sensitive butt'O'meter)
I gotta say i fitted a STI front strut brace to my BH9 and definatly felt the difference. Felt a lot better going round corners, also fitted a no name adjustable brace in the rear. That definate made a difference to how it felt
