Driveshaft loops lvvc
Zach
Basically any fabricator should be able to do it, there is a detailed list of what specifications they need to meet on the LVVTA website.
The rule about them is farcical, but I digress.
50mm x 3mm, not more than 200mm from a U-joint? iirc
Bolts 8mm (could be 6) If someone finds the actual specs please post
edit close : googled it & found this from 2008
Posted 25 March 2008 - 12:38 PM
They are pretty easy to make and not really something you need to copy. Different ride heights and driveshaft dia are going to change the loop dia.
Page two of my project thread has pics of mine about half way down page.
http://www.oldschool... ... 8&start=20
There are standards you must meet for the size metal to make them out of.
Think, but dont quote me on, 6mm thick, 60mm wide. 150mm from front driveshaft universal. Must have plates inside floor of car where the bolts come through. 4x bolts (Id go with M10's to be safe)
Gaz
source http://oldschool.co.nz/2011/forum/index.php?/topic/23229-driveshaft-loop/
and LMGTFY http://lvvta.proboards.com/thread/61/drive-shaft-safety-loops
more of a read http://www.gpforums.co.nz/threads/458781-Driveshaft-loop-help
at the worst just ask your certifier, if its Clint in AKL tell him "the information tent" sent you
Edited by Joker
Perfect! thanks man.
