Fire Extinguishers... Are there any standards?
Guitar_Guy
Looking at fitting a fire extinguisher in my car in case I do end up taking it
On the track at some point, also because they are just good to have.
Supercheap currently have 1kg jobbies for about $20 at the moment
Including a metal fitting bracket.
Will this be up to track standard or do I need something more specific?
Thanks!
I interpreted normal seated position to be when your strapped in. However, may not be the case.
There are other requirements too around them, but the ones I linked to meet these requirements.How they should be installed in the car as below.
Mounting / Location: Extinguishers shall be installed in accordance with the following:
(a) For hand-held extinguishers, a metal retaining system incorporating a quick
release metal strap/s shall be fitted (a minimum of two(2) quick-release metal
straps shall be required from 1 January 2013), secured to the structure of the
vehicle by a minimum of two(2) self locking ISO 8.8 M6 bolts with panel washers.
All hand-held extinguishers shall be positioned within easy reach of the
occupant/s while in their normally seated position (not mandatory for Single
Seater vehicles)
Edited by ballsrburning
There are also requirements such as the type and gauge etc. I highly recommend you always just look directly at the live MSNZ Schedule A for stuff like this. What's quoted here or on other sites may be completely wrong in six months (for example the strap change).
Yep I would say if you're even a little bit on fire on the track get the f*ck out of the car and let the marshals deal to it with their 8kg or whatever extinguisher.
If I had the choice of taking 5 seconds to get out of a harness or 5 seconds to get an extinguisher out of it's bracket I'd be out the door and doing my best Dr. Zoidberg across the infield.
Cars can be replaced, skin is quite a bit harder.
Plus if there's actually fire in the cabin something has gone badly, badly wrong and a 1kg extinguisher ain't saving **** at that point.
