Best Oil vs Price $$
glion
I've been looking into gearbox and diff oils. I'm trying to work out what the best oil vs price is.
Gearbox 4.3l
Diff 1l
Most recommended seems to be (Prices approx):
GEARBOX
Redline 75W90NS GL-5 - $180 (4.7l)
Motul Gear300 - $240 (5l)
Castrol Syntrax - $150 (5l)
DIFF
Redline 75W90 GL-5 - $39 (946ml could be a touch short)
Motul 90PA - $48 (2l, Twice as much as needed for this price)
At the moment it looks like a Castrol and Motul mix.
Anyone else got a recommendation or a source of good cheap oil?
Is the dccd or front mechanical. I have nfi how dccd works. Viscous diffs are sealed so no lsd requirement just need a gl5. You are getting ripped on gear oil. I can sell you a semi synthetic 85w90 gl5 lsd for 50ish. Perfectly fine for any lsd box/diff.
I'm not sure, its my understanding the Gearbox needs a oil without a friction multiplier, yet the rear diff needs the friction multiplier.
I've looked it up and all in know is the rear has a Torsen LSD. Can't find out what the front one combined with the gearbox is.
What oil can you supply?
Dont use oil with friction modifier in your gearbox, it destroys synchros.
DCCD stuff is designed to work with normal gear oil and without FM
Plated rear lsds need FM. Torsen doesnt
I like motul in my rear diff, redline in my gearbox and elf in my engine lol
 evowrx said:
Matt when you say fm do you mean on top if running an lsd oil or just running an lsd oil? So dccd does not require an lsd oil like a mech diff?
I buy the motul PA90 oil for the rear diff that has the FM in it already
Correct dont use FM with DCCD, well you can but it doesnt need it and your synchos will wear very quickly
But if you have a mech front lsd you will need to and suck it up.
