Cam sensor shielding
Im running the 3 pin hall cam sensors at the rear of the head. Do these need to be shielded? Ive been reading that hall arent susceptible to noise like the standard issue 2 pin sensors. Made a new loom to test wiring and seems to work fine unshielded.
Hall effect can be thought of as an almost-digital signal as it's a square wave (and is probably interpreted digitally anyway)
So it will be much less susceptible to noise because 5.1v or 4.9v still looks more or less the same as 5v (or whatever the signal reference voltage is) and is interpreted the same.
Likewise 0.1v or whatever you get from noise is still going to be considered "0" or "off" or "low" or whatever parlance the ECU prefers.
Short answer not required as long as the noise is less than a couple of volts... and if it is, you've got other problems!!
Probably quite a nice signal to put a scope on if you're learning how to use one - you'll get a nice relatively stationary square wave on screen once you've got the scope dialled and you can watch it accelerate when you rev the motor :)
The cam sensors being where they are get coated in oil. Guess that doesnt effect the signal? Same setup as v7 but hall. Will scope them sometime prob this weekend theyre a 3 tooth trigger at 90deg so should be easy to see like you say.
Going to reloom cop from ecu to pack and see if that fixes it too. Had endless issues with the wiring harness that jason liefting made.
