hunting idle??
snowbadger
rite
got a 97 sti wagon
twisted turbo bov 38mm wastgate screamer pipe setup
has developed a hunting idle
iv checked maf , all sensors , iac , checkd compression all of which is good
anybody got any ideas?? i was thinking mabee a vacum issue as the rocker breathers
and crank breather have not been plumbed in by the previous owner when the intercooler
was moved to the front
car drives swt apart from the weird idle
any thoughts??
cheers
she warms up fine
after short drive
wont sit at her normal heartrate
keeps dropping down almost stalling
iv tried the o2 sensor ,,no joy,,
will try a longer hose 2 the maf when i find 1
..was thinking mabee the bov could be sticking..
so had bov valve off clean reseal/ reset worked a bit but still hunting (dropping almost stalling) before it will idle normal
so a step closer as i have something of an idle..
also changed the plugs for platinum ones this morn
ther was a mix of plugs in there from previous owner
