Cranking but taking ages to fire
nztintin
Hey
My forester (98 stb, 230,000kms) is taking a lot longer than normal to fire and on cold mornings its taking a couple of attempts to get it to fire. It's cranking fast enough from the sounds, just doesnt fire. I checked the battery voltage and it drops to about 10v on cranking.
The plugs aren't that old, the cars had an afm, coolant temp sensor, fuel pump and a couple other things in the past 20,000kms to try fix a different issue it had.
The battery is pretty old (came in the race car when i bought it 4 years ago, unknown age) but 10v doesnt seem to bad according to the all knowing google.
any suggestions out there what it could be?
Well the car wouldnt start this morn, cranked too slow and drained the battery
I swapped the battery out of the race car and its still slow, It started at least but it still sounds real slow now. The race car battery is an Odyssey PC925MJT 330CCA, it starts the race car fine, even if i crank it for ages to get oil pressure etc and the race car was used on sunday so battery should be fully charged, voltages were 13.9v car running, 12.8v car off, 11.5v when cranking.
I'm starting to wonder if the starter motor is dying, not spinning fast enough/drawing too much current from the battery. how easy are the starter motors to overhaul brushes etc?
