Independent Radiator setup for Turbo
nismovzr2003
Hey guys,
Just wondering if anyone out there has thought about or is running a seperate radiator setup for their turbo?
Is this something that could a be a good option for track use or running high boost?
Just wondered what would be involved with the setup, i.e. blanking off existing inlet/outlet from head, installing a new cooler for example a smaller radiator or air to air cooler, 12v water pump and tank?
Any thoughts, ideas would be greatly appreciated.
Cheers.
Yeah done it on my car, drops about 10 or so degrees from the engine coolant temp (that was my reasoning for doing it). I used an RS legacy WAIC pump, got an alloy reservoir made up to hold the water, then plumbed it through a cooler that I have mounted in the RH side front guard area.
you just need to blank off that port on the back of the RH head, and the one on the header tank that feeds the turbo and you are good to go.
Let me know if you want some pics and I'll dig some out.
To blank off the port, get a 1994ish Toyota Corolla sump plug from Repco. Comes with a plastic washer.
If you're crafty about it, you could do it without an additional circuit, you could just take the line off the back of the head, run it through a separate radiator (I'm thinking where the TMIC sits) then through the turbo and back to header tank...
I think that defeats the purpose, you want to remove the turbo-generated heat from the coolant eh?
I basically wondered if it would resolve two problems;
1. Decrease the engine coolant temp thus keeping temps at more of a moderate range when doing endurance type track meets, and
2. Having a separate cooling system for the turbo would help keep down intake air temp?
Thoughts?
Thoughts?
I don't think it would make three fifths of feck all difference to intake temps, the gasses going through your turbo are doing it at about half the speed of sound so there isn't a lot of time for thermal transfer and the turbo is still going to be hot as hell anyway.
