Plasti Dip
cyberjays
I did my rally car:
https://scontent-a.xx.fbcdn.net/hphotos-xaf1/v/t1.0-9/10304792_10152361284750933_3896402578076281505_n.jpg?oh=c2c972ef3682fe4cb9414207858c49cf&oe=55631785
It's a pain in the arse to maintain, as it peels with too much touching and it is easily damaged with oil/petrol too... It however is a ****load cheaper than painting a car properly... If you don't really care about your car/image, then try it. Or just buy one can and paint one panel to see. It does peel right off, but that's also it's downside, it peels right off!
Ps, took about 15 cans to do the car properly.
Vivian
It shouldnt peel off that easy unless its not enough coats/ you've left open edges for it to lift from (if that even makes sense, it does in my mind) but you're using it for a rally car so I could understand it peeling off easily as it gets more abuse then a daily driven road car..
I did my wheels and wing mirrors over a year ago now? And theyre perfectly fine to this day, only thing was the wheels had to be touched up after the tires got changed(understandable) and theres maybe one stone chip on the wingmirror which went through the plastidip but the paint underneath is fine.. I know its not much of a comparison to a whole car being done but its some insight I guess..
oooh and pick your colour wisely as some dont suffer to well when they get dirty...
I spent a week down in the South Island on Targa in the car and the paint peeled off the front edge of the right rear door, mainly from me rubbing up against it as I climbed out of the car between stages. So any area that has high wear on it like that and door handles it will peel from over time. But it is also very easy to touch up and you don't have to blend it, just put another coat on and it seals it up nicely.
I would definitely say try it out on a panel and see what you think.
I had black on my wheels for over a year and it lasted pretty good.
Its just a pain with the brake dust as they end up turning a bronzie kind of black.
Have to be careful when cleaning as if you are to vigorous you can end up rubbing it off.
