Vacuume leak of doom
Zach
Car idling at 16 In_Hg.
I've inspected all the hoses/lines and there all mint as, Tried multiple mechanical boost gauges,
I've pulled the entire intake including intercooler. (not intake manifold yet but tempting.)
I'm totally dumbfounded its all mint, the BOV looks mint too but Im not totally sure about it cuz it is quite old.
Only thing I not looked at is the head breather hoses, there old plastic ones can they cause vac leaks though? Thanks any advice/ideas are welcome. I have acess to every tool udner the planet and I wont put the car back together til about 3pm, thanks.
If you can't pressurise it with the airline with the intake blocked then you probably have a HUGE leak. If you've definitely got it blocked and you still can't get pressure, get someone to hold the airline down and go listen at the exhaust, if it's whistling out there then you've got a stuck or leaking exhaust valve.
Could try blocking off the BOV completely take it out and plug the hole. That will tell you quickly if it's leaking. Apart from that then splits in the early plastic intakes on v1-2 wrx is pretty common (Had it happen on all of mine). They split on the intercooler pipe where it joins the turbo.
lol yea I found the cronic leak, it would only start leaking over 12psi, one of the rubber hoses pops open only at over 12psi tho..... also the bov is leaking :( which sucks cuz I really like the way my bov sounds and its hella rare im really gutted bout that one.
Im gona clamp that hose up now. Also Im looking to buy a good condition BOV, atmos or recirc I don't mind. Thanks for the help guys.
One coming from the bov, One coming from my 90degree bend going into the turbo and you know the big hose running from the intake to the ICV, well under 12psi it would lift up and seep air and then close again, so it was a bit of a stealth one, I sealed them up except for the bov, im sitting on 19-20 vac atm so not bad, but I know once I start boosting the bov will be leaking hard. :(
Edited by Zach
