How do I Move odometer reading Foward ?
wyatt31
Alright before you say anything i am not trying to move it back !! to make it look like it has less Kms / Miles
I found a STI gauge cluster that i want to put into my Wrx. Problem is the sit one has 57 thousand kms and my car has 192 thousand kms.Can they be changed in order to read correctly ?
Sti gauge http://www.upjpn.jp/yahoo/car_photo/...6140/m0005.jpg
wrx gauges http://www.j-spectuning.com/pictures/omori04dual1a.JPG
Also doest it matter that my current cluster goes up to 260km/hs and the new one goes up to 180km/h
Edited by wyatt31
yeah my car is a version 8 wrx ( with the normal gauges, green lights ) and i want version 8 STI gauges with the red back light, shift light. Will it be a problem if my current gauge goes to 260km/h and the sti one goes to 180km/h or will the ECU or gauge work it out and show the correct speed ?
Not exactly the same case, but I did a 180 -->260kmh (and back) swap on my my BH, everything worked fine.
I briefly looked into fitting a version 8 STI cluster into my BH, would require a full rewire though. The cluster has an internal CPU that would need the right programme to adjust the kms.
I was going to try powering the cluster on a bench, then feed 5v into the speed wire hopefully giving 180kmph. Then just time it/watch it till the kms are what I originally had (180kph x 24hrs = 4320km). Not sure if it would work, just a theory...
Edited by Rosssub
How fast is "very fast"
I'm sure there's a lot of very, very simple circuits that could provide the pulse you're after. A good old 555 IC could probably generate them plenty fast for what you're after.
A 555 will happily output pulses 100x that rate. You could make up a circuit to do it on a breadboard, easy peasy.
A TL494 would do 300khz, if 100hz gave you 180kph then 300khz would give you 540000kph ;)
Edited by boon
