injector plugs
tydon
unfortunately i had to put new plugs on my v3/4 loom and replaced them with the ones off my TT loom i made sure the colours on the injector plug wires matched up. And now i cant tell which ones are longer or shorter
Also check you haven't plugged in the cam/crank (can't remember which one it is) sensor in incorrectly.. as it uses the same plug. Made that mistake on a previous TT > ST conversion I did. It would turn over but not start! It's the one by the oil filler cap.
Cam is the one but wont run at all if thats the case.
