running rough v3/4 conversion
tydon
Pull the drivers side plugs out, fit them into the passenger side leads and earth them onto the block while someone turns it over. To make sure the plugs are ok.
Then pull both drivers side leads off, fit them onto the passenger side and do the same test. To see if the leads are ok.
Pull the spark plugs out one at a time, connect them up and earth them onto the block. Should be a good strong blue spark. Plugs can definitely cause it to drop a cylinder or more.
Once you are sure there is spark at all four cylinders, then check for fuel/injectors etc.
Also during test drive it would hesitate sometimes then boost clean was quite spluttery. And on decel it would sound like it was running on all 4 at higher revs . Quite boggy down low but would pick up and boost then spit and hesitate . Definitely feels like spark or fuel . Frustrating
 tydon said:
ok so i tested each lead and plug there was spark coming out of each lead and plug it wasnt a really strong blue spark but there was something there
Weak spark is no good, are there any hairline cracks in the coil pack?
Edit: I've got a good set of plugs here I can send you, probably best to get some different leads/coil pack. Maybe a compression check before spending any money on it?
Edited by Rosssub
so just a wee update. I got sick of trying to diagnose it and search for the issue so i bought another car minus turbo. I bought back my old wagon converted from twin to single for the motor as i know it was defintely a good one and a much better motor in general. dropped it in last night plumbed evreything back up again amd boom issue was gone... im figuring the motor was abit buggered
