topmount External intercooler
Zach
Chop away the bonnet a bit (where the scoop normally is anyway), alter the piping a tad so you can have your intercooler sitting just outside of your bonnet. Anyone done this? I've been thinking about it because you don't need to cut away at your bumper you still get the benefit of short piping and the benefits of a frontmount if you angle up a bit. I've never heard of it being done before but just thinking about it it seems like a no brainer? opinions?
that's ok then. I was just thinking is all. I've already got a rotated manifold fmic setup not yet installed. The external tmic is a flop idea then, always good fun to post my ideas best way to learn haha. One of these days I'll strike gold im sure of it xD Thanks.
WoF guy would probably spew about external projections as well, if you hit a pedestrian and they got wrapped around your ETMIC I imagine it wouldn't go well.
V-Mount with low-mount turbo is the future. I'll be trying it out on my testbed ****box some time this year.
it would look like someone vomited gasket goo onto your engine
and it will still leak.
you can pull it all apart, clean everything nicely, Threebond it all back together with washers under the bolts to compress the old gasket some more and see how you go. its a bit hit and miss
otherwise, new gaskets.
 evowrx said:
Would be a heap less efficent than the stock shroud/scoop I would think. That is if Im reading what you're writing correctly. The big issue with tmic is the heatsoak.
this guy nailed it, go read up on ducting and why NASCARS or V8 super cars have small intakes for their radiators
air will take path of least resistance around the cooler rather than thru it
hence Exposed coolers suck and are only for show/look at meeeee
I suppose semi relevant to that point is the amount of top mount intercoolers you see with no shroud from the scoop
Fine when fan forced on the dyno but in real life half the airflow just goes naaaah ill scoot round the sides thanks
