What s the main different between oil catch can & air oil separator?
Do you have examples that you're interested in? As the names are often interchanged and probably talking about the same thing.
Sometimes the oil is drained back to the sump. Sometimes the air is vented to atmosphere and sometimes it'll go back to the intake.
It's going to get harder to pass a wof (or maybe cert) with a venting catch can as far as I'm aware.
There are a lot of subtle differences between the various kits available so it's best to judge a particular setup rather than trying to figure out what is "best" purely off what someone may call their kit.
All the air oil separators i've seen just sit on the oil fill port so very different to catch cans. Don't quote me on that though. All i know is from looking for one myself over the last little while.
From what i've read in other forums catch cans seem to pick up more than aos's especially in situations when the cars being pushed hard, track days and such, but you obviously have to empty them, unless some of them feed back as you say koom.
Also i reckon aos's look tidier than a big tank in an already tight engine bay. Just my 2c...
A catch can is an air/oil separator... it's function is to remove oil vapour from the air on it's way from the engine to the intake.
Some people (mainly yanks in n/a v8s) use a purely inline approach... but in a turbo, as soon as you increase boost, those things are
100% useless because you are going to have liquid oil flowing about, not just oil vapour.
Edited by loner
 Scoobydoo said:
Note the text is red that most likely means any car that is a few years old and/or has the boost cranked... so everyone in NZ :)
"Please note this product is designed to combat factory amounts of blow by. If you have a built motor or are experiencing abnormal amounts of oil consumption, this product may not work for you."
The difference between a "catch" can and a oil air seperate is exactly that - one catches the oil and stores it - and the other puts the oil back into the sump
Basically they're both the same thing / just plumbed differently
I don't think I'd run one that fed back into the sump. I had a small Cusco catch can on my high km BH engine, only connected to the head breathers. All that ever came out of it was oily coloured condensation, maybe 20ml per month. Still enough to contaminate sump oil though.
That condensate is part of the reason that the operating temp of the oil is hot enough to boil off the water based contaminants.
Depends, on your normal, modified road car I'd say yes.
If doing trackdays, some tracks tend to cause Subaru's to blow out a lot of oil from the heads. In that case, it's better off going back to the sump otherwise in extreme cases you can end up with more oil in the catch can than the motor.
So again, there's no simple answer as it all depends on the intended usage.
