Banjo Bolt Part Numers
Rosssub
OEM 1mm Banjo Bolt:
1mm/1.5mm:
1mm/6mm:
Old 6mm Turbo feed/New 6mm Turbo feed & AVCS feed (superseded p/n)
OEM gasket, (copper washer) for all 12mm Banjo Bolts:
10mm copper washer is 803912040.
Edited by Rosssub
Turbo list and bearing types:
http://forums.nasioc.com/forums/showthread.php?t=1141476
My VF36 has a 1mm banjo at the turbo end. According to this thread below, if it was fitted to AVCS heads. It would have a 6mm banjo at the head end, so that the AVCS banjos still get full oil pressure. So the VF36 roller bearing/oil pressure only drops right at the turbo:
Oil feed thread from Nasioc archive:
http://bbs.22b.com/forums/archive/index.php/t-11376.html
Which makes sense that the dual AVCS engines, with 4 x 6mm AVCS banjos, would have a high flow 12mm oil pump.
OEM oil pump sizes and part numbers:
http://www.clubsub.org.nz/forum/index.php/topic,42733.0.html
So for my EJ207 Short Block/Version 6 STI Heads/VF36 Turbo/10mm Oil Pump, I\'ll be using 1mm banjo bolts on my turbo oil feed. ;D
Swindogs thread on turbo oil starvation - Banjo oil filter failure:
http://clubsub.org.nz/forum/showthread.php?1287-Turbo-Oil-Starvation
AVCS filter failure threads by Ichi Ban:
http://clubsub.org.nz/forum/showthread.php?22885-New-AVCS-Issue-(V7-on)-oil-feed
http://clubsub.org.nz/forum/showthread.php?20079-Attn-ALL-OWNERS-OF-CARS-THAT-HAVE-AVCS
My BH5B TT turbo oil feed filters removed:
Edited by Rosssub
