adapter loom
fbssub1
ok made an adapter loom, got and issue on the BC5 4 plug loom you have B126/3 pressure sensor (power) & B126/4 pressure sensor(signal) and on the WRX ECU pin out it has only 1 out put B136/17 pressure sensor.
WHICH wire from the bc5 do I connect to the WRX pin???
Cheers Brian
Cheers Brian
Should be B126/4 pressure sensor signal.
But I think you will have to connect the other BC5 wire (B126/3 pressure sensor power), to a sensor power source. (5v source?).
 Rosssub']
Cheers Brian
TPS? its a 5v , but that means I have 2x 5v feeds going to the wrx tps pin, will that be a issue
Should be ok, looks like most ECU\'s run multiple sensors off one feed.
For the WRX ECU you have to only have one MAP Sensor wire, it must have a 5v Sensor Power Source Pin somewhere though?
What\'s the ECU code?
Edit: If there is only one TPS Pin, then that\'s the signal wire from the sensor to the ECU.
The TPS must have a power feed too?
