Oil Pump options 10mm/11mm/12mm
Rosssub
I have a 10mm EJ208 Oil Pump that\'s done 214,000kms. I have a Rebuilt Version 7 EJ207 Block and Version 6 STI Heads.
I priced a new Genuine Replacement today through Subaru:
10mm Oil Pump - 15010AA300 - $377 + GST
$T2eC16hHJFoE9nh6qSZ1BP4rQ-qgtQ~~60_57.J
12mm Oil Pump - 15010AA310
11mm Oil Pump - 15010AA360
Oil Seal - 806733030
O-Ring - 10991AA001
Some threads on upgrading OEM Pumps and why not to:
http://forums.nasioc.com/forums/showthread.php?t=2466900&page=3
http://legacygt.com/forums/showthread.php/upgrade-oil-pump-11mm-08-sti-design-worth-iti-186773.html?s=88ac40a959cfa01e652f1c694d39f9c9&
http://www.wrxtuners.com/forums/f103/upgrade-my-oil-pump-27727/
With an EJ207 STI with Version 6 STI Heads (non AVCS), I\'m still thinking I\'ll stick with the 10mm Pump? ???
What are others using? For what set up? How\'s your Oil Pressure at Idle/Redline?
 gotasuby said:
12mm pump is way cheaper. We use that in rally car. Idle hot is 30psi. 78-85psi from 5-7000 rpm
Is that with a Double Cross Drilled Crank/VVT-AVCS?
My OEM EJ208 Oil Pressure Specs are:
98 kPa (1.0 kg/cm2, 14 psi) or more at 800
rpm
294 kPa (3.0 kg/cm2, 43 psi) or more at
5,000 rpm
 Rosssub']
rpm
5,000 rpm
AFAIK, the 12mm Pump will max at 85psi because that is the Relief Valves PSI level. So your pump is maxing oil flow at 5000rpm, then Bypassing Oil above that.
So with my Low Pressure Specs with the 10mm Pump, (I think Relief/Bypass is early 70psi?).
If I fit the 12mm Pump, my Oil will flow so fast it wont cool properly. Which will effect Oil Heat Viscosity/Engine Life etc?
10mm pump is all we\'ve ever used, some say on factory clearances a 12mm pump is unessessary and can heat or aerate the oil. I check the torque of the screws on the back cover, and dot punch the screws slightly to help prevent them coming loose.
And $377 plus for a 10mm pump? Yikes.
Interesting, the 10mm Pump also rums relief at 85psi, 11mm Pump 78psi:
Source:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2521160
From this original thread, covering Oil Viscosity/Flow Rates/PSI per RPM etc:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1861033&page=1
Edit: See the Main difference between the 10mm and 12mm Pump, is evident at 6000rpm PSI. The 12mm pump PSI is double the 10mm Pump.
For a non competition engine with normal clearances a 10mm pump is perfectly adequate imho. If you are looking for a little more pressure you can shim the relief valve.
I have used a 12mm pump in two competition engines with oil squrters, AVCS, larger bearing clearances and a 23 row oil cooler and never had any problems with oil temps or bearing failures.
After reading those threads, I\'m beginning to think I should have gone 11mm at the largest and changed out the oil pick up for aftermarket item.
 Leighos']
Partsouq.com looks pretty appealing with the current exchange rate right about now...
https://partsouq.com/en/search/search?q=15010AA300
Bought one of these a few weeks ago for $150NZD delivered, took only a week to arrive.
Just brought one, along with these:
[quote name='Rosssub said:
Ouch...Genuine through Subaru, for VF38 Twin Scroll:
UP Flange Gasket - 44011FE040 - $59.00 + GST Each
DP Flange Gasket - 44011FE050 - $65.00 + GST Each
Exhaust Manifold - 14038AA000 - $16.00 + GST Each
Partsouq.com
UP Flange gasket - 44011FE040 - $13.77
DP Flange Gasket - 44011FE050 - $15.77
Exhaust Manifold - 14038AA000 - $3.60
https://partsouq.com/en/search/search?q=44011FE050
I just brought a full set, with a new OEM 10mm Oil Pump, for $185nzd delivered.
Lets see how delivery is...
$185 nzd delivered. ;D
 Leighos']
Thanks Leighos, new OEM 10mm pump from partsouq.com ready to go:
