BBOD Converted to Version 6/Link G4 Solenoid Control Box.
Rosssub
This is my BH5B Twin Turbo, Solenoid Control Box/BBOD.
I\'ve removed all Screws that hold the Sensors in place:
Unbolted 2 last Sensors then removed the Internals, leaving the MAP Sensor installed:
I find it easiest, when removing Vac Hoses, to grip the Hose over the Nipple with Pliers. then twist the Hose, breaking the Seal.
Then they pull off fairly easy:
I\'ve left the Map Sensor in, then refitted the ECV Solenoid for my new Boost Controller:
I\'ve T\'d a Boost Gauge hose into the MAP Sensor Line. Then Refitted the Hose #12 Vacuum Feed/One Way Valve, to feed the Vac Tank if needed.
Then routed everything to the OEM BBOD Vac Ports. My new Single Turbo Solenoid Control Box ready to install:
Then installed a 3 Port Solenoid into the Top Vac Ports, for easy changeover later on:
I have 6 Spare Vac Solenoids, Mountains of Vac Hose and Multiple Vac T\'s and Junctions.
Eventually I\'ll fit my Electronic Boost Gauge Sensor in, when removing one of the Boost Solenoids. Also fit Boost Sensor connected to my Turbo Timer, ending up with no Vac Hoses through the Firewall and all Sensors/Solenoids tucked neatly away.
 broku420gtb said:
i mean if i just use the map and evc with my link ill be fine?.. on the evc one end to waste gate and one to turbo?, and the map just piped with vac line to the mani?
Map straight to Manifold.
ECV - Is the Exhaust Control Valve Solenoid. Identical to the TT\'s Primary Boost Solenoid in the F/L Guard.
I\'d planned to use this 2 Port OEM Boost Solenoid while running the Version 6 STI ECU. Boost Control Hoses will be set up identical to OEM, one hose T\'d off Turbo/Waste Gate Line, the other hose Bleeding back to Intake.
3 Port Solenoids run one hose from Turbo to Solenoid, then one hose from Solenoid to Turbo. Bleeding out the 3rd Port.
Read up on \'Open Loop\' and \'Closed Loop\' Boost Control.
