Dash bulbs
B4 I was 250T
  • 4 months later...
theres white sti gauges for be/bh as well - 300k speedo / 10k tach (haha, try using that more than once)
normally go for around $6-700 mark, was some on ebay recently (try yahoo auctions japan too?)
slight waste of $$ but whatever floats your boat - would be better off trying to make a v5/6 sti cluster fit in place instead
actually thatd be pretty cool - i love the dash in those with the central tach etc
Member on here had one a while ago sold $350 I think with speedo drive.
  • 2 months later...
 D-Style said:
If you have the "black face" custer you can only change the rings around the dials. They are T5 type .
My RSK B4 has issues with the rings blinking on/off, working/not working - any ideas? (theyve been modified to bright blue)
 B4_685']
If you have changed to LED\'s sometimes they work themselves loose from time to time as they arent a tight fit
I had to "glue" a couple of LED\'s in to the plugs to stop them blinking.
  • 1 year later...
Just wanted to touch on this thread about my findings,
I have recently pimped out my v4sti cluster with leds.
For the back lighting i used the bigger one of the 2 first, Wasn't happy as they noticeably light up one section of the cluster while the surrounding parts stayed dim, so i ordered another style and have had success with them (the led on the left) it lights up the background with little to no dim spots.
The LEDS can be purchased here.. http://www.ebay.com/itm/390821903204?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
You only need 5 or 6 for the dash so the left over ones can be used for park lights etc
V4 have t-10 size while v5-v6 clusters use t5 for back lighting and the check lights are already fitted with leds.. but for the v4 you use t-5 size these ones as the normal t-5 leds wont fit through the circuit board.. http://www.ebay.com/itm/20x-White-6000K-58-70-73-74-T5-Dashboard-Gauge-1-5050-SMD-LED-Wedge-Bulb-Light-/291120953634?pt=Motors_Car_Truck_Parts_Accessories&hash=item43c8293922&vxp=mtr
Edited by hijacka
  • 5 months later...
Looks good man :)
