Odd Problem... a few Warning lights at certon Revs on Leone
Old Skool Subbie
The Charging light, Brake warning light, Brake Fuild warning light is on from from idle to 2500 rpm.
It goes away from 2500 to 3700 rpm. After that those lights start glowing again. I also noticed a weird miss in the higher Revs.
Battery Hasn\'t gone flat so dont think its the alternator?
Any Ideas?
Thanks
The alternator when at idle has not got enough revs to allow it to charge properly, then as the revs come up it will start to charge, then as the revs get higher the brushes are being forced away from the rotor,causing it to only charge partially.
Try another/new alternator OR replace the brushes on yours, this is what i would do,then if it still does it I would look into it deeper.
