Applied model code - what does it mean?
How does it break down? What does each number/letter mean?
eg, GC8E2DD
G = Impreza
C = Sedan
8 = 2.0 4WD
E = revision #
2 = 2 door (coupe)
But what about the DD bit? Or does it mean you get girls with a big rack?
I know whith the BG's, ED means GTB. And Most STi's will be ED as well i think. All the STi's i looked at on trademe returned an ED (didn't look at any coupes).
Ah, lan_killa matt just found it in the IRC,
the last number, D = 5speed manual, P = 4spd auto.
Second to last is the grade, 8 = WRX, E = STi, D = RA or R.
not complete
[table]
[tr][td]G [/td][td]G[/td][td]Impreza[/td][/tr]
[tr][td][/td][td][/td][td][/td][/tr]
[tr][td]C[/td][td]C[/td][td]1st Gen Sedan[/td][/tr]
[tr][td][/td][td]F [/td][td]1st Gen Wagon[/td][/tr]
[tr][td]8[/td][td]1[/td][td]1.5L 2WD[/td][/tr]
[tr][td][/td][td]3[/td][td]1.6L 2WD[/td][/tr]
[tr][td][/td][td]4[/td][td]1.6L 4WD[/td][/tr]
[tr][td][/td][td]6[/td][td]1.8L 4WD[/td][/tr]
[tr][td][/td][td]8[/td][td]2.0L 4WD[/td][/tr]
[tr][td][/td][td]A[/td][td]1.8L 4WD (air suspension?)[/td][/tr]
[tr][td]A[/td][td]A[/td][td]Model year[/td][/tr]
[tr][td][/td][td]B[/td][td][/td][/tr]
[tr][td][/td][td]C[/td][td][/td][/tr]
[tr][td][/td][td]D[/td][td][/td][/tr]
[tr][td][/td][td]E[/td][td][/td][/tr]
[tr][td][/td][td]F[/td][td][/td][/tr]
[tr][td][/td][td]G[/td][td][/td][/tr]
[tr][td]4[/td][td]2[/td][td]2 Door[/td][/tr]
[tr][td][/td][td]4[/td][td]4 Door[/td][/tr]
[tr][td][/td][td]5[/td][td]5 Door[/td][/tr]
[tr][td]8[/td][td]2[/td][td]CF[/td][/tr]
[tr][td][/td][td]3[/td][td]CS / HS[/td][/tr]
[tr][td][/td][td]5[/td][td]CX[/td][/tr]
[tr][td][/td][td]6[/td][td]HX[/td][/tr]
[tr][td][/td][td]7[/td][td]WRX - RA[/td][/tr]
[tr][td][/td][td]8[/td][td]WRX[/td][/tr]
[tr][td][/td][td]A[/td][td]HX / Edition S[/td][/tr]
[tr][td][/td][td]D[/td][td]STI RA / STI R[/td][/tr]
[tr][td][/td][td]E[/td][td]STI Version[/td][/tr]
[tr][td]D[/td][td]D[/td][td]DOHC Turbo Centre Diff 5MT[/td][/tr]
[tr][td][/td][td]G[/td][td]SOHC NA 5MT[/td][/tr]
[tr][td][/td][td]J[/td][td]SOHC NA Center Diff 5MT[/td][/tr]
[tr][td][/td][td]P[/td][td]SOHC NA 4AT[/td][/tr]
[tr][td][/td][td]R[/td][td]DOHC Turbo 4AT[/td][/tr]
[tr][td]B[/td][td]B[/td][td]Legacy[/td][/tr]
[tr][td]G[/td][td]C[/td][td]1st Gen Sedan[/td][/tr]
[tr][td][/td][td]F[/td][td]1st Gen Wagon[/td][/tr]
[tr][td][/td][td]D[/td][td]2nd Gen Sedan[/td][/tr]
[tr][td][/td][td]G[/td][td]2nd Gen Wagon[/td][/tr]
[tr][td][/td][td]E[/td][td]3rd Gen Sedan[/td][/tr]
[tr][td][/td][td]H[/td][td]3rd Gen Wagon[/td][/tr]
[tr][td][/td][td]L[/td][td]4th Gen Sedan[/td][/tr]
[tr][td][/td][td]P[/td][td]4th Gen Wagon[/td][/tr]
[tr][td][/td][td]2[/td][td]1.8L 2WD[/td][/tr]
[tr][td][/td][td]3[/td][td]1.8L 4WD[/td][/tr]
[tr][td][/td][td]4[/td][td]2.0L 2WD[/td][/tr]
[tr][td][/td][td]5[/td][td]2.0L 4WD[/td][/tr]
[tr][td][/td][td]7[/td][td]2.2L 4WD[/td][/tr]
[tr][td]5[/td][td]5[/td][td]2.0L 4WD[/td][/tr]
[tr][td][/td][td]9[/td][td]2.5L 4WD[/td][/tr]
[tr][td][/td][td]A[/td][td]? 4WD Air Suspension[/td][/tr]
[tr][td][/td][td]C[/td][td]2.5L[/td][/tr]
[tr][td][/td][td]E[/td][td]3.0L 4WD[/td][/tr]
[tr][td]5[/td][td]4[/td][td]4 Door[/td][/tr]
[tr][td]9[/td][td]2[/td][td]EI[/td][/tr]
[tr][td][/td][td]3[/td][td]MI (1st Gen)[/td][/tr]
[tr][td][/td][td]3[/td][td]TX[/td][/tr]
[tr][td][/td][td]4[/td][td]TI (1st Gen)[/td][/tr]
[tr][td][/td][td]4[/td][td]TX-S[/td][/tr]
[tr][td][/td][td]5[/td][td]VI[/td][/tr]
[tr][td][/td][td]6[/td][td]VZ[/td][/tr]
[tr][td][/td][td]7[/td][td]RS Type R (1st Gen)[/td][/tr]
[tr][td][/td][td]7[/td][td]RS[/td][/tr]
[tr][td][/td][td]8[/td][td]RSK[/td][/tr]
[tr][td][/td][td]9[/td][td]GT[/td][/tr]
[tr][td][/td][td]A[/td][td]RS Type RA (1st Gen)[/td][/tr]
[tr][td][/td][td]A[/td][td]250S[/td][/tr]
[tr][td][/td][td]B[/td][td]Lancaster[/td][/tr]
[tr][td][/td][td]C[/td][td]VZ-R (1st Gen)[/td][/tr]
[tr][td][/td][td]C[/td][td]GT-B[/td][/tr]
[tr][td][/td][td]E[/td][td]GT-B Ltd[/td][/tr]
[tr][td][/td][td]F[/td][td]Brighton[/td][/tr]
[tr][td][/td][td]G[/td][td]TS Type R[/td][/tr]
[tr][td][/td][td]H[/td][td]Lancaster-S[/td][/tr]
[tr][td][/td][td]J[/td][td]RS Type B[/td][/tr]
[tr][td][/td][td]K[/td][td]Lancaster 6[/td][/tr]
[tr][td][/td][td]L[/td][td]Lancaster 6 ADA[/td][/tr]
[tr][td][/td][td]M[/td][td]RS25[/td][/tr]
[tr][td]P[/td][td]A[/td][td]DOHC NA 2WD 5MT[/td][/tr]
[tr][td][/td][td]D[/td][td]DOHC Turbo Centre Diff 5MT[/td][/tr]
[tr][td][/td][td]E[/td][td]DOHC NA 4AT[/td][/tr]
[tr][td][/td][td]F[/td][td]DOHC NA Centre Diff 5MT[/td][/tr]
[tr][td][/td][td]J[/td][td]SOHC NA Centre Diff 5MT[/td][/tr]
[tr][td][/td][td]P[/td][td]DOHC Turbo 4AT[/td][/tr]
[tr][td][/td][td]R[/td][td]SOHC NA 4AT[/td][/tr]
[tr][td][/td][td]S[/td][td]DOHC NA SS-4AT[/td][/tr]
[tr][td][/td][td]T[/td][td]DOHC Turbo SS-4AT[/td][/tr]
[/table]
Guest lan_killa
 ReubenH said:
Second to last is the grade, 8 = WRX, 7 = WRX RA, E = STi, D = STI RA or R, B = WRX-SA (V1 Only)
Guest lan_killa
That list that kamineko looks alot more complete/detailed than the one I was looking at... but still needs a few updates
Guest lan_killa
 kamineko said:
if the whole list isn't helpful i can remove it
should probably build up a completeish list and sticky it somewhere
This has been covered a zillion times before but I guess all that info went out with the last meltdown.
Redux;
From
http://www.catherineandken.co.uk/sti/wrx.html
Based on the APPLIED MODEL number on you VIN plate you should be able to find out, your exact model type.
The 7 digit "applied model" code found on the vehicle identification plate inside the engine bay is decoded in the following way.
1.Series code G=Impreza S=Forester B=Legacy etc.
2.Body type F=Wagon C=Sedan
3.Engine type 8=2.0L Turbo
4.Year code A=MY93 B=MY94 C=MY95&96 D=MY97 (facelift) E=MY98 F=MY99 G=MY00
5.Number of doors 2=2 door coupe 4=4 door saloon 5=5 door wagon/hatch
6.Model type 8=WRX 7=RA type E=Sti D=Sti Type R & RA
7.Transmission D=5 Speed Manual AWD P=4 Speed Automatic AWD
All information comes from the Subaru Impreza WRX Sports Parts Catalogue
Someone sticky that in the appropriate place...
Guest lan_killa
that info isnt complete nor correct in places
EG it says 8 = 2.0L turbo, yet HX20 and HX20s have an 8 in that same spot yet are both N/A's
The russian outback owners site has it. But i lost the links when i got a new laptop. So if anyone reads russian - please.
Theyve also got gear ratios for all the auto transmissions and a lot of other cool info.
I got a weird one for yas. Some data to add i guess
BG6BK3G
NZ new, or AU new LX, 2.2L SOHC, fwd, 5spd.
B = Legacy
G = Gen 2 wagon
6 = 2.2
B second rev.... wut, no, it was a bloody 94!! Gen 2 BG's came round in 96. I guess NZ/AU new does it differently
K. For... Kool door? I will note, it's a wagon, but it lacked the roof rails.
3 for TX? i guess 3 is LX in NZ/AU new
G = SOHC, 5spd FWD. i guess.
And isn't BG4 1.8 too? there's quite a few missing there.
<table border="1" cellpadding="4"><tr><td align="center">Version</td><td align="center">Model</td><td align="center">Option</td><td align="center">?</td><td align="center" valign="top">A
i
r
c
o
n</td><td align="center" valign="top">A
B
S</td><td align="center" valign="top">Q
u
i
c
k
r
a
c
k
S
t
e
e
r</td><td align="center" valign="top">S
u
n
r
o
o
f</td><td align="center" valign="top">P
o
w
e
r
W
i
n
d
o
w</td><td align="center" valign="top">C
e
n
t
r
a
l
L
o
c
k
i
n
g</td><td align="center" valign="top">A
i
r
B
a
g</td><td align="center" valign="top">R
o
o
f
S
c
o
o
p</td><td align="center" valign="top">4
P
o
t
F
r
o
n
t
s</td></tr><tr><td>A</td><td>WRX</td><td>BX</td><td>010</td><td></td><td></td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>BJ</td><td>020</td><td>●</td><td></td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>EJ</td><td>030</td><td>●</td><td>●</td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>-</td><td>040</td><td>●</td><td></td><td></td><td>●</td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>EF</td><td>050</td><td>●</td><td>●</td><td></td><td>●</td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td>WRX RA</td><td>-</td><td>060</td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>-</td><td>070</td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td>B</td><td>WRX</td><td>BX</td><td>010</td><td></td><td></td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>BJ</td><td>020</td><td>●</td><td></td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>EJ</td><td>030</td><td>●</td><td>●</td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>EF</td><td>050</td><td>●</td><td>●</td><td></td><td>●</td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td>WRX 4AT</td><td>BJ</td><td>090</td><td>●</td><td></td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>EJ</td><td>100</td><td>●</td><td>●</td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>EG</td><td>100</td><td>●</td><td>●</td><td></td><td></td><td>●</td><td>●</td><td>●</td><td></td><td></td></tr><tr><td></td><td></td><td>EF</td><td>120</td><td>●</td><td>●</td><td></td><td>●</td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td>C</td><td>WRX</td><td>BJ</td><td>021</td><td>●</td><td></td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>EJ</td><td>031</td><td>●</td><td>●</td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td></td><td>EF</td><td>051</td><td>●</td><td>●</td><td></td><td>●</td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td>WRX RA</td><td>-</td><td>061</td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td>STI V2</td><td>BJ</td><td>170</td><td>●</td><td></td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td>STI V2 555</td><td>BK</td><td>170</td><td>●</td><td></td><td></td><td></td><td>●</td><td>●</td><td></td><td></td><td></td></tr><tr><td></td><td>STI V2 RA</td><td>-</td><td>190</td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td>●</td><td></td></tr><tr><td></td><td></td><td>XN</td><td>190</td><td></td><td></td><td>●</td><td></td><td></td><td></td><td></td><td>●</td><td></td></tr></table>
huuuur i'll finish typing that up later -_-
pity its also incomplete info
